Contributor II
Aruba Controller with LDAP and NPS
Hi all,
I am looking to integrate Controller with Ldap or NPS.
My requirement is i need to achieve user authentication and machine authentication. can we achieve from LDAP??But if we can, user authentication happens first and machine auth only when user logs off and logs on. How does LDAP holds or knows when the machine is authenticated???
and I knew that we can do machine authentication from NPS like writing a policy dat hostname belongs to computers group in AD.
Again how does it hold machine and user at the same time and sen the response to controller ??
Contributor II
Re: Aruba Controller with LDAP and NPS
is it possible to do machine authentication when we integrate with LDAP ?
Machine authentication is only possible with a RADIUS server and termination on the RADIUS server.
Tim Cappalli | Aruba Security
