Aruba IAP 207 Wireless Mesh
Hello Everyone,
i am new to aruba iap and i am planning to implement wireless mesh.
can you help advise the step by step procedure on doing the initial configurations.
Re: Aruba IAP 207 Wireless Mesh
There are literally dozens of posts here on how to set up mesh with IAP. Just search for 'setting up Instant IAP mesh' for multiple links. They both need to be brought up together to establish the cluster first, disable the extended SSID, and create at least one SSID to get rid of the default SSID. Details are in multiple posts here.
Jerrod Howard
