I have 2 Aruba IAP305 one connect by cable and one that will not be connected by cable.
In the first setup both IAP are connected by cable.
Then is disabled extend SSID and set Eth0 Briding enabled on the IAP that will be not connected by cable.
Rebooted both IAPs and disconnected the cable from the mesh point.
The IAP will not connected to the mesh portal.
Please could someone advise if I am missing someting.
With kind regards,
Patrick Hofman
