I have an installation of 5 x IAP205s. They have all gone through the initial configuration, have discovered each other and all are visible from the GUI presented by the virtual controller. However, when I make a configuration change from the GUI it does not replicate to two of the five access points (the configuration delta from the "show delta" command doesn't change to the new version shown by the VC). And error messages like those below are shown in the log of the VC.
Aug 20 15:27:36 cli[1737]: <341132> <WARN> |AP UKMH1PWAPIAP205-01@10.228.168.21 cli| Check sum error for AP-10.228.168.23, slave 4137 vs master 15892, error_cnt 4, recover_sent 0.
Aug 20 15:27:36 cli[1737]: <341132> <WARN> |AP UKMH1PWAPIAP205-01@10.228.168.21 cli| Check sum error for AP-10.228.168.23, slave 4137 vs master 15892, error_cnt 5, recover_sent 0.
Aug 20 15:27:36 cli[1737]: <341132> <WARN> |AP UKMH1PWAPIAP205-01@10.228.168.21 cli| Check sum error for AP-10.228.168.23, slave 4137 vs master 15892, error_cnt 6, recover_sent 0.
Aug 20 15:27:36 cli[1737]: <341132> <WARN> |AP UKMH1PWAPIAP205-01@10.228.168.21 cli| Check sum error for AP-10.228.168.24, slave 39096 vs master 15892, error_cnt 3, recover_sent 1.
Aug 20 15:27:36 cli[1737]: <341132> <WARN> |AP UKMH1PWAPIAP205-01@10.228.168.21 cli| Check sum error for AP-10.228.168.24, slave 39096 vs master 15892, error_cnt 4, recover_sent 1.
Aug 20 15:27:36 cli[1737]: <341132> <WARN> |AP UKMH1PWAPIAP205-01@10.228.168.21 cli| Check sum error for AP-10.228.168.24, slave 39096 vs master 15892, error_cnt 5, recover_sent 1.
The software on all the APs has been updated to the latest version via the GUI and the "show version" command on all APs show:
UKMH1PWAPIAP205-01# show version
ArubaOS (MODEL: 205), Version 6.4.2.3-4.1.1.4
Website: http://www.arubanetworks.com
Copyright (c) 2002-2015, Aruba Networks, Inc.
Compiled on 2015-04-05 at 01:53:10 PDT (build 49446) by p4build
Any suggestions?
