Aruba MM and MD with RAP deployment
In my lab environment I tested Aruba products. Currently I tested Remote Access Points (RAP) over IPSec.
When I deploy standalone wireless controller (VMC) and provisioning RAP on remote location everything works ok and I can connect to RAP SSID and have access to my central location where I have controller.
In another scenario I deploy 2 Mobility Masters (virtual) in VRRP and 2 Mobility Controllers (VMC) in cluster and with VRRP for AP. But if I now provisioning RAP on remote location, RAP cannot connect to my controller (via IPSec) in central location. The configuration is the same as in standalone controller.
Is this scenario with MM and MD in cluster and RAP supported in version 8.2.0.2? If it is supported, do I need to configure any additionally settings compare with standalone configuration? Do I need any special licenses for this implementation (currently I have PEF and RF Protect licenses).
I follow User Guide from Aruba support website.
If somebody have similar design scenario please help me with configuration.
Thank you.
Re: Aruba MM and MD with RAP deployment
NAT is not supported on a cluster because of how the clustering works.
You will need to assign public addresses (not ideal) so best to deploy a managed controller (not part of a cluster) just for the RAPs
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thank you Victor Fabian for answer.
I have another question.
If I have following design:
- 2 Mobility Masters in VRRP and 1 Mobility Controller (MD) ( Everything behind firewall) and then RAP in remote location (via IPSec).
Is this deployment supported or need Mobility Controller with public IP Address to work RAP on remote location?
Thank you.
This is a valid design , a non cluster controller can use NAT
Thank you
Victor Fabian
Thank you
Victor Fabian
I tested this design with 2 MM (in VRRP) and 1 Mobility Controller managed by Mobility Master. And then deploy RAP on remote location (via IPSec). But do not work.
If I have Mobility Master, did I need to configure any additionally settings to work properly?
Thank you.
Are you saying you cannot have a cluster of 2 MDs for redundancy as a RAP deployment?
What is the AOS 8 redundancy solution for RAPs?
Bruce Osborne - Wireless Engineer
ACCP, ACMP
All opinions written here are my own and do not necessarily reflect the views and opinions of my employer or Aruba Networks
Not saying that, you can terminate RAPs on cluster MDs but you will need to assign a public IP address to each MD because in a cluster scenario NAT is not supported
You can use the same Redundancy mechanisms used in 6.x with non-cluster controllers and NAT at your firewall if your environment can’t use the above
Thank you
Victor Fabian
Thank you
Victor Fabian
Thank you
Victor Fabian
I have deploy 2 Mobility Master (virtual) with VRRP IP (so controller is connecting to VRRP IP address) and 1 Mobility controller (virtual) managed by Mobility Master.
And the RAP still not working.
If I deploy standalone Mobility controller (virtual). Everything works.
Do I have to configure additionally settings on Mobility Master to RAP work via IPSec on remote location.
Thank you
Victor Fabian
We currently only have one standalone RAP controller for 6.x.
Our 8.x plan is to have a cluster of 2 MDs., each with public IP addresses and a cluster public IP address. I assume this is supported?
ACCP, ACMP
