Frequent Contributor II
Aruba MST200 Config Guide
I need  Aruba MST200 Config. Guide , I mean the one similar to the attached  of MST 1200 that shows part numbers ,antennas & accesories ...
Re: Aruba MST200 Config Guide
The MST200 is an all-in-one unit, so there is no other equipment needed other than a power injector.
The antenna is built into the unit.
It requires 802.3at power, any compatible injector or switch will work.  Our PD-9001G is the part number for the injector we sell.
