Occasional Contributor I
Aruba Mobility Controller - problem with access the website but through wired able to access it
My customer not able to access some of the website through wireless, but can access through wired. All of the website can surf such as google, yahoo etc, only their own portal cannot access through wireless.  When they use wired connection, then they able to access it. Wireless and wired network are on same network, it is flat network.
There's similar issue before reported on this community but it's for IAP-105 and the workaround was disable content filtering on IAP. But my client using mobility controller. Please help.
Re: Aruba Mobility Controller - problem with access the website but through wired able to access it
