Regular Contributor I
Aruba OS 6.4.0.3, is there a cli or gui way to view Firewall hits in Real time?
Say I am connecting to the controller via a RAP or even just a different subnet. I'd like to be able to see hits as they come through the firewall, or perhaps even be able to filter from the IPs coming in.
As far as I can see I only see hits to specific ACLs, which is all well and good, except that I didn't configure any of them so I am being forced to reverse engineer it.
Anyway, long story short, is there a way to tell what IP/host is attempting to connect to the controller at a given time?
Re: Aruba OS 6.4.0.3, is there a cli or gui way to view Firewall hits in Real time?
Is not real time but you can take look using the show acl hits or from gui firewall hits
Thank you
Victor Fabian
Lead Mobility Architect @WEI
?Show datapath session? will show all traffic through the controller. You can add include or exclude modifiers to narrow down the traffic.
The problem with show acl hits, or the firewall hits section of the gui is that I don't see a way to tell which host is hitting there. I can see the New Hits and the Number of hits, but is there a way to actually see what is hitting that ACL?
Thanks olino, that's exactly what I needed.
Did anyone ever answer this or provide any options.
There are quite a few answers in this thread.  Did you find any of them satisfactory?
