Regular Contributor II
Aruba OS and netflow
Can the Aruba OS support netflow?
Moderator
Re: Aruba OS and netflow
Not today
Exporing flow records out of Aruba Controllers is a roadmap item. We can  take detailed roadmap discussions offline and my contact number  is 408 754 8003.
Ash.
Aruba Product Mgmt.
Aruba Product Management
Any updates on the Netflow support for Aruba OS? Is there a version that has this feature targeted?
Trusted Contributor I
looking at previous responses where the remark Airwave does this was provided i really doubt you are going to see this being added soon.
could be wrong though :smileyhappy:
The ability to monitor wireless top-talkers, etc using standard Netflow protocols and solutions would be a huge benefit. Is this available, or on the roadmap?
