Frequent Contributor II
Aruba OS for 7200 controllers
My network is made up 2 6000 controllers with M3 and other 2 6000 controllers with SC1, I'm going to replace 2 controllers (SC1) for 2 new 7200 controllers, the question is:
What's the minimum Aruba OS supported by 7200 controllers?.
I'm currently running OS 5.0.3.0, so what path should I follow to upgrade??
Thank you
Re: Aruba OS for 7200 controllers
The min is 6.2 but I would recommend our latest 6.3 code.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
You'll want to upgrade to 5.0.4.12 then to 6.2.
6.2 is supported on 72x0, M3, 3x00, and the 600 series controllers.
Tim Cappalli | Aruba Security
The SC1 do not support 6.X code. That likely prevents them from upgrading their existing infrastructure to 6.X.
Bruce Osborne - Wireless Engineer
ACCP, ACMP
All opinions written here are my own and do not necessarily reflect the views and opinions of my employer or Aruba Networks
Yes, you are right.
Due to it, we are planning upgrade to 2 7200 ( replacement of 6000 with SC1), but the problem is that 7200 come with Aruba OS 6.x (minimum) and our network run AOS 5.0.3.
So, the upgrade should be
1.- upgrade our network to 5.0.4.12.
2.- upgrade to 6.x, taking out our SC1 controllers.
3.- install the new 7200 with 6.x
