Occasional Contributor I
Aruba OS8 and IAP 315
Does anyone have a date when Aruba OS8 (on controller) will support the IAP 315 in campus controller configuration?
Re: Aruba OS8 and IAP 315
AOS 8.0.1 is targeted for release this week and will support the 315. Note that there is no stragith migration path from AOS 6.x to 8.0, as any migration from 6.x to 8.x will require the use of a migration tool that should be provided on or shortly after the AOS 8.0.1 release.
Jerrod Howard
Thank you for the follow up, I'm looking to do a full building test deployment and have everything working under 6.5.  I was thinking since ArubaOS8 was going to be the next step I might as well build my test deployment around it.
If you are starting from scratch in a new location, then sure, go for it!
Jerrod Howard
