Contributor I
Aruba Outdoor AP-274 ANT 3x3 D608 Antennas
Does anyone know what  the External Antenna Parameters should be set at for my 3x3 D608 Antennas?
I currently have the 5GHz Antenna Gain (dbi) set at 20
And the 2.4 GHz Antenna Gain (dbi) set at 20
Is this correct or should it be different?
MVP
Re: Aruba Outdoor AP-274 ANT 3x3 D608 Antennas
You should be setting the value of the respective antenna gain for each radio. So when you provision the gain value within the AP settings, it shoulud be 7.5dBi for both. So make sure to fix that, or your AP will be running very low since it 'thinks' you have a 20dBi antenna attached to that AP.
Jerrod Howard
Sr. Techical Marketing Engineer
