Contributor II
Aruba RAP Connection to VMC FC FY FDC state mean ?
Aruba RAP Connection to VMC  FC FY FDC state mean ? anybody can help to explain what is the FC FY FDC mean ? Thanks
Re: Aruba RAP Connection to VMC FC FY FDC state mean ?
Type "show acl hits" to understand what might be blocked.
Contributor II
AOS83) [mynode] #show acl hits
User Role ACL Hits
Role  Policy  Src  Dst  Service/Application  Action  Dest/Opcode  New Hits  Total Hits  Index  Ipv4/Ipv6
Port Based Session/Route ACL
Port ACL Hits
ACL  ACE  New Hits  Total Hits  Index  Ipv4/Ipv6
(AOS83) [mynode] #show crypto ipsec sa
IPSEC SA Active Session Information
Initiator IP     Responder IP     InitiatorID         ResponderID         Flags    Start Time      Inner IP
111.203.231.162  172.31.4.51      192.168.88.48/32    0.0.0.0/0           UT     Jul  4 08:52:59   192.168.88.48
111.203.231.162  172.31.4.51      192.168.88.52/32    0.0.0.0/0           UT     Jul  4 09:04:41   192.168.88.52
36.110.67.20     172.31.4.51      192.168.88.38/32    0.0.0.0/0           UT     Jul  4 08:22:45   192.168.88.38
111.203.231.162  172.31.4.51      192.168.88.41/32    0.0.0.0/0           UT     Jul  4 08:29:28   192.168.88.41
111.203.231.162  172.31.4.51      192.168.88.21/32    0.0.0.0/0           UT     Jul  4 07:30:51   192.168.88.21
36.110.67.20     172.31.4.51      192.168.88.53/32    0.0.0.0/0           UT     Jul  4 09:04:57   192.168.88.53
36.110.67.20     172.31.4.51      192.168.88.49/32    0.0.0.0/0           UT     Jul  4 08:53:05   192.168.88.49
111.203.231.162  172.31.4.51      192.168.88.31/32    0.0.0.0/0           UT     Jul  4 08:00:10   192.168.88.31
36.110.67.20     172.31.4.51      192.168.88.18/32    0.0.0.0/0           UT     Jul  4 07:24:03   192.168.88.18
36.110.67.20     172.31.4.51      192.168.88.44/32    0.0.0.0/0           UT     Jul  4 08:40:47   192.168.88.44
36.110.67.20     172.31.4.51      192.168.88.20/32    0.0.0.0/0           UT     Jul  4 07:29:57   192.168.88.20
111.203.231.162  172.31.4.51      192.168.88.23/32    0.0.0.0/0           UT     Jul  4 07:36:43   192.168.88.23
36.110.67.20     172.31.4.51      192.168.88.24/32    0.0.0.0/0           UT     Jul  4 07:41:40   192.168.88.24
36.110.67.20     172.31.4.51      192.168.88.54/32    0.0.0.0/0           UT     Jul  4 09:10:48   192.168.88.54
111.203.231.162  172.31.4.51      192.168.88.27/32    0.0.0.0/0           UT     Jul  4 07:48:32   192.168.88.27
111.203.231.162  172.31.4.51      192.168.88.19/32    0.0.0.0/0           UT     Jul  4 07:25:00   192.168.88.19
36.110.67.20     172.31.4.51      192.168.88.30/32    0.0.0.0/0           UT     Jul  4 07:59:16   192.168.88.30
111.203.231.162  172.31.4.51      192.168.88.55/32    0.0.0.0/0           UT     Jul  4 09:10:51   192.168.88.55
36.110.67.20     172.31.4.51      192.168.88.36/32    0.0.0.0/0           UT     Jul  4 08:17:04   192.168.88.36
36.110.67.20     172.31.4.51      192.168.88.32/32    0.0.0.0/0           UT     Jul  4 08:05:09   192.168.88.32
111.203.231.162  172.31.4.51      192.168.88.29/32    0.0.0.0/0           UT     Jul  4 07:54:26   192.168.88.29
111.203.231.162  172.31.4.51      192.168.88.37/32    0.0.0.0/0           UT     Jul  4 08:17:51   192.168.88.37
36.110.67.20     172.31.4.51      192.168.88.34/32    0.0.0.0/0           UT     Jul  4 08:11:06   192.168.88.34
111.203.231.162  172.31.4.51      192.168.88.35/32    0.0.0.0/0           UT     Jul  4 08:11:53   192.168.88.35
111.203.231.162  172.31.4.51      192.168.88.50/32    0.0.0.0/0           UT     Jul  4 08:58:54   192.168.88.50
111.203.231.162  172.31.4.51      192.168.88.25/32    0.0.0.0/0           UT     Jul  4 07:42:37   192.168.88.25
111.203.231.162  172.31.4.51      192.168.88.47/32    0.0.0.0/0           UT     Jul  4 08:47:05   192.168.88.47
36.110.67.20     172.31.4.51      192.168.88.42/32    0.0.0.0/0           UT     Jul  4 08:34:32   192.168.88.42
111.203.231.162  172.31.4.51      192.168.88.45/32    0.0.0.0/0           UT     Jul  4 08:41:10   192.168.88.45
111.203.231.162  172.31.4.51      192.168.88.43/32    0.0.0.0/0           UT     Jul  4 08:35:19   192.168.88.43
36.110.67.20     172.31.4.51      192.168.88.22/32    0.0.0.0/0           UT     Jul  4 07:35:58   192.168.88.22
36.110.67.20     172.31.4.51      192.168.88.51/32    0.0.0.0/0           UT     Jul  4 08:59:07   192.168.88.51
36.110.67.20     172.31.4.51      192.168.88.28/32    0.0.0.0/0           UT     Jul  4 07:53:23   192.168.88.28
36.110.67.20     172.31.4.51      192.168.88.46/32    0.0.0.0/0           UT     Jul  4 08:46:49   192.168.88.46
111.203.231.162  172.31.4.51      192.168.88.33/32    0.0.0.0/0           UT     Jul  4 08:06:20   192.168.88.33
36.110.67.20     172.31.4.51      192.168.88.26/32    0.0.0.0/0           UT     Jul  4 07:47:33   192.168.88.26
111.203.231.162  172.31.4.51      192.168.88.39/32    0.0.0.0/0           UT     Jul  4 08:23:34   192.168.88.39
111.203.231.162  172.31.4.51      192.168.88.56/32    0.0.0.0/0           UT     Jul  4 09:16:29   192.168.88.56
36.110.67.20     172.31.4.51      192.168.88.57/32    0.0.0.0/0           UT     Jul  4 09:16:41   192.168.88.57
Flags: T = Tunnel Mode; E = Transport Mode; U = UDP Encap
       L = L2TP Tunnel; N = Nortel Client; C = Client; 2 = IKEv2
Hi Lin,
The deny (D) flag is seen for the traffic traversing port 1/0 on the controller.
Please run the command "show ip access-group" to see the firewall policy applied on that port.
Contributor II
(AOS83) [mynode] #show ip access-group
GE 0/0/0:
Port-Vlan Session ACL
SessionACL            Vlan     Status
GE 0/0/1:
GE 0/0/2:
Port-Channel 0:
Port-Channel 1:
Port-Channel 2:
Port-Channel 3:
Port-Channel 4:
Port-Channel 5:
Port-Channel 6:
Port-Channel 7:
Interface vlan 1:
Interface vlan 4095:
(AOS83) [mynode] #
