I'm looking for a document wich explain how roaming beetween Master/ local controller works.
Actually, I'm using two 7210 controllers in the same bulding with active/active redundancy (master/local).
One in two floors, AP terminate on Master and one in two floors AP terminate on Local controller. To make this possible I configured two VRRP instance and two AP system profil. AP from impair floor terminate its GRE tunnel in VRRP 1 and AP from pair floor go to VRRP 2.
So I would be sur there will not be any trouble if a client will roam from master controller to local controller.
Thank you in advanced for your help.
Rémy
