Frequent Contributor I
Aruba VMC AOS8.3 with RAP Connect in Preshare Key not work ?
Frist, I will thanks two friends Mr
(AOS83) [mynode] #show tpm cert-info
This platform type does not support TPM.
(AOS83) [mynode] #show inventory
Mgmt Port HW MAC Addr : 00:16:3E:06:B6:FE
HW MAC Addr : 00:16:3E:05:A5:40
Product key# : MCE39A72C
Activate license : Not Applicable
Active device type : MC-VA-1K
(AOS83) [mynode] #
2. some friend tell us we can do pre-shared key to provision our RAP as CAP frist, but the problem is our RAP can not access VMC in one local network, all of our RAP can only access our VMC from Internet.
3. we have console cable and can access RAP apboot.
What should we do next step ? thanks.
Regular Contributor II
Re: Aruba VMC AOS8.3 with RAP Connect in Preshare Key not work ?
Hi
If you open port 8211 as well you can get a AP as CAP on the VMC.
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
