Frequent Contributor I
Aruba VMC and VMotion
I'm working with a customer getting a standalone VMC working on VMWare Enterprise. The appliance is working as expected until you move it to a different ESX host in the VMWare cluster with VMotion.
It takes a long time before you can ping the VMC again. The GUI is accessible after a while but is not fully operational (XML query errors) and clients are not receiving an IP address properly for a while.
restarting service httpd doesn't fix the GUI access. Rebooting the VMC does the trivck but is obviously not a solution.
The documentation on virtual controllers is all build on VMWare Standard. Is there anything special you need to do to get it running properly with all functionality on VMWare Enterprise?
Thanks for letting me konw. It's kind of urgent.
Regards, Erik
