Occasional Contributor I
Aruba VoWLAN - Shoretel and Polycom 84XX
I have a lab environment with Aruba 650, Shoretel PBX/IP phones and Polycom 84XX handsets. I was able to setup calls pretty much from following the available configuration guides, however I had no voice path between 84XX client in either PTT or voice call mode.
I ended up putting additional firewall rules to allow the PTT multicast traffic and RTP between wifi clients.
I can understand the need for the PTT rule, but the user-user RTP rule looks like a bug in Aruba SIP ALG, since it should behave consistenly.
Could anyone comment on this?
thanks
darren
Re: Aruba VoWLAN - Shoretel and Polycom 84XX
What are your firewall policies on the Aruba controller for those devices?
All the rules were taken from this document http://supportdocs.polycom.com/PolycomService/support/global/documents/support/user/products/voice/VIEW_Aruba_Mobility.pdf
I had to build another session rule for the PTT function, IPv4 any to multicast destination 224.0.1.116
and another session rule IPv4 user-user any traffic to get voice path between 2 wifi phones.
So let's see the ones you have configured.  Whatever role you have configured, please type "show rights <role>" so we can see.
attached.
Here is what you can do:
While you are making a call, type "show datapath session table <ip address of client>" and paste the output in here so we can see if your RTP sessions are being dropped or classified.
2 outputs attached, one with the working call case (user-user rtp rule) and one without.
What are the three hosts in the outputs? I do not see any denies....
252 and 244 are the Polycom 84XXs.
200 & 250 are the Shoretel (200 is SIP proxy address)
I was looking to see denies. I did not see any. Does this work with an allow all?
