Occasional Contributor I
Aruba Wi-Fi Zones; help setting up the zones correctly
Hey, so we have 6 aruba routers all running together brodcasting two SSIDS; one is a password protected for employees only network (on vlan 1). The other SSID is a throttled guest network that is open publicly (on vlan 40). We have two buildings. The large building has 5 aruba access points and need to be broadcasting both SSIDS. The last aruba router is in a smaller building and we just want it to broadcast the password protected SSID, so we don't want the guest network in that building. I tried setting up the zones but couldnt manage to get it to work, so I thought I would ask for the communities help. It seems simple enough in my head, but in software I guess not haha.
Thanks in advance!
Re: Aruba Wi-Fi Zones; help setting up the zones correctly
Please see here:  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-broadcast-ESSID-specific-to-Single-IAP-in-a-cluster/ta-p/192969
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
