Frequent Contributor II
Aruba Wireless Controller and Alcatel-Lucent Wireless Controller
Hello all,
is Aruba and Alcatel Lucent wireless controllers and APs are the same in term of IOS, commands and configuration ? (is there any official reference for this issue?)
Is people using Alcatel Lucent controllers need to access aruba support website to download new IOS updates and releases ?
Aruba
Re: Aruba Wireless Controller and Alcatel-Lucent Wireless Controller
Alcatel customers access Alcatel Support resources, not Aruba's directly.
They will have different/branded/Alcatel Tested versions of the ArubaOS posted there.
I see, but in term of configuration people able to configure ARUBA controller can configure Alcatel-Lucent controller, is not it ?
Alcatel will test the IOS but they will not have their own developed IOS version with different command and operation ?
My concern is about the ability to configure the alcatel controllers.
Aruba
The commands are indeed the same.
