Are you trying to learn strictly from documentation or do you have some hardware to play with?
If you seriously want to learn the products I would advice getting a controller to play with. Manuals are great and all, but only go sofar.
If you do have a controller, start from the beginning.. run some wizards and figure out what they did config wise. If anything is unclear, then open the manuals (or come back here).
