Aruba Wireless Network speed is unstable
my wireless speed is not stable on operation room in my hospital out side the room its working fine i have 3 Aruba Controllers master locale locale and Aruba 105 APs .
what could be the problem and what is the solotion .
Note. my network is in hospital and the problem in  Opration Room haveing medical equiped room .
Waqar.
Re: Aruba Wireless Network speed is unstable
Where are the access points mounted?
What devices is the WLAN unstable with?
Colin Joseph
Aruba Customer Engineering
You should start by looking at the RF health ( Utilization / Interference) on the controller dashboard
How many SSIDs are you running ?
Do you have drop broadcast/multicast enabled?
Are you only experiencing issues in that location?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
dear Sir.
AP is Mounted outside the OR .
the device is HP Z book 17 G2 leptop .
Does that area of the hospital have lead lined walls?
Sent from Nine
Tim Cappalli | Aruba Security
its an operation room for sure it will be lead lined walls .
tell me the solution please .
You probably need to hire a local expert who can tell you about your physical mounting options. We cannot easily advise you since we cannot visit your site.
Colin Joseph
If they're lead lined walls, you'll have to put the AP in the room.
Sent from Nine
Not that it's cost effective, but if you have to deploy an AP inside the room, use the AP-275 and remove the plastic solar shield (not required but the shield could protect areas that could lead to bacteria and other pathogens to remain). It's IP66/67 rated and can sustain exposure to water, spray wash, etc. It can be mounted up higher and yet still survive exposure to the regular cleanings and decontamination. The 275 also supports conduit directly into the ethernet port, which would allow the protection of the ethernet from said cables, and provide greater prevention for any contaminants to be left behind after cleaning.
Just a thought. While the 275 is a bit more expensive (for a reason), the cost of a 275 is a drop in the bucket compared to the cost of maintaining an operating room.
Jerrod Howard
appropriate sir i will try that way as you directed.
thanks
