Aruba Wireless questionnaire document
Is there a questionnaire that helps sizing an Aruba Wirless solution?
Thanks!
Re: Aruba Wireless questionnaire document
Have a look at the validated reference design guides, these will help you size and deploy the required wireless solution.
https://community.arubanetworks.com/t5/Validated-Reference-Design/tkb-p/Aruba-VRDs
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
