Aruba and CCX?
In short, got a question that does Aruba support CCX (Cisco Compatible Extensions)? From what I found it doesn't but I hope you guys can prove me wrong :)
Tom
Re: Aruba and CCX?
Does not.  Those are Cisco proprietary.
Re: Aruba and CCX?
So I figured, but just wanted to be 100% sure - Thanks :)
