Frequent Contributor I
Aruba and Certificates
Can the Aruba controller or Clearpass manager (or guest) utilize user based certificates for authentication for smartphones (IOS, BB, Android)?
Re: Aruba and Certificates
Yes, both support EAP-TLS
Tim Cappalli | Aruba Security
ok, how would I get the cert on the devices?
Trusted Contributor I
For ClearPass, you would buy Onboarding licenses, which would assist in generating the certificates and pushing them to your mobile devices.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
would that remove users from having to enter creds in a captive portal?  we have an issue with our users domain accounts constantly locking out.. generally from their smart devices.. hardcoded passwords for the employee wifi, email, etc.... so less devices that have hard coded creds the better..
and would it be with Clearpass Manager or Guest?
Yes, it would relieve your users from having to type their credentials into a captive portal.  Once the devices are onboarded, they automatically connect to your 802.1X SSID using the certificate that was pushed to the device.
They're technically the same product now.  Although, configuration of onboarding still requires going to the Guest area for configuration.  You can't do it all through one window.
The ideal setup would be to use ClearPass Onboarding which would take care
of the enrollment process for the users. Onboard is not included in the
base license.
The do-it-yourself version would be to stand up active directory
certificates services and users can generate and install client
certificates. The ClearPass can be configured to authenticate the user
with their certificate.
