Contributor II
Aruba and VRF
Hi!
Will Aruba support VRF (Virtual Routing and Forwarding) on controllers and switches? If so, do you have any specific roadmap release and estimated time for it?
Thank you,
Chris
Re: Aruba and VRF
I can't say that I have seen that on a roadmap.
Is there a specific use case where you could not use your own switching fabric to do this, instead of the controller?
Re: Aruba and VRF
We have requested this functionality for the MAS.
There are many use cases such as PCI compliance.
Tim Cappalli | Aruba Security
Re: Aruba and VRF
Right.  On the MAS.  I will let the switching gurus answer...
Aruba
Re: Aruba and VRF
Hello All,
VRF-Lite is on our roadmap but not currently committed to a release. I recommend you post your feature request on the idea portal to help us gauge the level of interest so that we can schedule it accordingly.
https://arubanetworkskb.secure.force.com/cp/ideas/ideaList.apexp
Best regards,
Madani
Super Contributor I
Re: Aruba and VRF
+1
Ryan Holland, ACDX #1 ACMX #1
The Ohio State University
Trusted Contributor I
Re: Aruba and VRF
I second this!  Would be very handy to have.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: Aruba and VRF
Hi All,
Any updates on this?
Thank you.
