Contributor II
Aruba controller PMKID+OKC and 802.11r
Can I configure aruba controller with both PMKID+OKC and 802.11r?
Say if the client support 802.11r, then use 802.11r, if not fallback to PMKID+OKC.
My objective is to minimize constant reauthentication by later IOS devices, while
maintaining backward compatibility with legacy wifi clients.
Re: Aruba controller PMKID+OKC and 802.11r
You can enable both, it but it is up to the client which is leveraged in that situation.
