Aruba controller
I have AP 135 device 8 pcs I need controller which model is good
#AirheadsMobile
Regular Contributor II
Re: Aruba controller
Starting with a 7005 could do the trick, it is limited to 16 AP max. Only if you don't plan to extend the amount of AP's beyond 16.
Or buy a second hand one, many choices depending on your budget.
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
