Contributor I
Aruba eBay Home Lab
I plan to buy Aruba AP from eBay for my home lab.
QUESTIONS:
1. Is ClearPass an AP Controller
2. Do I must use hardware controller to manage AP
3. Can I use RAP-3 with ClearPass
4. How long trial license of ClearPass
5. What is cheapest AP and controller model that supported by latest Aruba OS
thanks
Re: Aruba eBay Home Lab
1) ClearPass is a policy engine/RADIUS server
2) If they have a model beginning with "AP" (not IAP), then yes you need
a controller
3) A RAP-3 would be used with a controller, not ClearPass
4) A trial license is 90 days
5) I'm not sure of pricing, but a 3400+ controller with 105+ APs would
probably your best bet.
Tim Cappalli | Aruba Security
Contributor I
Cisco, AeroHive, Ruckus have virtual controller.
Are you sure Aruba doesn't have virtual controller?
Aruba IAPs elect a virtual controller. Campus APs require a hardware controller.
Aruba does not have a virtual controller that supports wireless, no. That may change in the future but as for right now, there is not.
Jerrod Howard
Contributor I
I just bought refurbished Aruba Dell W-3400 and 2pcs of AP-125.
I don't know it has license or not.
Without any license, what it can do or can't do.
Or can I get trial license
How long the license last.
Can I renew the license by reset to factory default.
This just for practice only
thanks
<If there are no AP licenses, you cannot do anything>
<You would have to speak to an Aruba Sales Person or reseller to get a trial license>
<The trial license lasts 30 days, but can be used twice for a total of 90 days>
<The trial license can be reset by factory default, yes>
thanks
Contributor I
Thank you for your rocket response
I am not so clear here
Do you mean after 90days, I reset to factory default, apply old license then I can extend another 90days
That's correct. Using the trial/eval keys, you can re-use them 3 times for up to 90 days. After 90 days or before, you will have to backup the config (NOT a flash backup), wr erase all, and then either re-configured (great practice) or paste in the new config. you cannot use the flash backup as it will restore the old key timers and will show expired upon reboot.
Jerrod Howard
Why you don´t search to become an Aruba Partner?
I mean, with this investment, sure you can get an AP204 and the controller, yes, you can go with ebay.
Aruba offer a great discount for NFR devices.
I wonder why you don´t go directly with Aruba, may be by budget (How much did you spend on this kit?).
Have a nice day.
