Aruba equipment into Brazil
I have a couple of deployments coming up in Brazil and I'm told there are some big hassles with getting stuff into the country and they need some sort of licence.
Anyone know what sort of documentation I should provide to facilitate the customs clearance etc?  Already have the data sheets, but anything else would be helpful.
ACCP, ACCX #817, ACMP, ACMX #294
Contributor II
Re: Aruba equipment into Brazil
You need a company in Brazil to provide the documentation to "import" the products and pre pay the fees. If you send without this, you will pay a lot of taxes...
The best way is contact Aruba to help you. They have a distribuitor on Brazil (Westcon) that do this things for us (i'm a reseller here on Brazil).
Paulo Raponi
