Aruba mobility 7030 + NPS + 802.1x authentication
I have problem with authenticating wireless users over 802.1x with AD See below my setup:
Mobility contrioller:
-PEF licence installed
-AP provisioned and working fine
-I have one SSID configured as machine authentication (set to enforce machine authentication) - this one works perfect
- the second SSID is using AD authentication (created OU on AD and configured few test users) - and this one does not work.
As you can see in the last screenshot.
I've unticked dial-in tab restarted NPS service few times and no joy.
If anyone had experience with similar setup before which would help me to resolve this problem ?
Re: Aruba mobility 7030 + NPS + 802.1x authentication
Your clients are hitting the "connections to other access server" policy.  That means that whatever NPS policy you have configured is too restrictive, so it is not being processed.
HI Colin,
do you mean my "SGS-Users$" string in NPS conditions tab or "domain users" ?
Would you clarify what you mean ?
regards
Piotr
It is not hitting your "Domain Users" policy.
Why do you have the calling station ID requirement setup in your policy?  Please remove that if it is not needed.
