Aruba "instant mode with mesh config"
Does aruba instant mode supports mesh configuration in a controllerless environment?
Doesn 100 series APs support that?
thanks,
Re: Aruba "instant mode with mesh config"
Mesh is supported on dual-radio Instant APs. Take a look at Chapter 4 in the Instant User Guide
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=13053
Tim Cappalli | Aruba Security
Super Contributor I
Another link that might interest you since  you are on Instant:-
http://cloud.arubanetworks.com/instant-training
Normal Guy
Do we need controller to enable mesh with instant mode?
Super Contributor I
Nope, there is no need for a controller. IAP have the capability like what Tim had pointed out read that chapter and you should be good to deploy MESH IAPs.
Normal Guy
Yes, 105, 115, 135, etc , support it
Yes, you can do It with 105, 135, 115, etc
