Occasional Contributor I
Aruba3600/6.4.2.12 DHCP issues
Hello I am running the Aruba3600 on software 6.4.2.12 - everything works fine. I have a windows 200R2 network with clients authenticated by a Windows Server and then assigned an IP by the same Windows DHCP server. My problem is that each time I upgrade to any operating software above 6.4.2.12 at least half my clients start to experience problems receiving an IP address. The moment i roll back to 6.4.2.12 everything is fine again???
Re: Aruba3600/6.4.2.12 DHCP issues
Did you open a TAC case?  It could be something specific within your environment along with Aruba code changes.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi
I am fairly new at this. How do I open the TAC case? Does it have to go through my reseller?
Please send an email to support@arubanetworks.com and they will guide you.
