ArubaOS 6.4.2.4 (Also tested on 6.4.2.3) | WIP & RFP question AD-HOC + NO UCC INFO at all
Hi Guys,
Good morning,
I just deployed aruba controller at one of my sites , and the client asked me to config the WIP module... i did it as alawyas - but , then i we check and notice that AD-HOC devices..even if they marked to be contained - are able to connect (iPhone6 ... keep changing his channles... and also Galaxy NOTE 3 teethring working even due it's marked to be contained)
Detect Ad-HOC is marked
and also Protect aginst ad-hoc + Enahched protection against AD-HOC..but still.
it's seems that the WIP module taking couple of good minutes to see the AD-HOC ..and even after that..it's just no blocking it as needed.
Please advise?
2nd question
UCC just not showing any data...even due that i marked on the Stateful Firewall > Global Settings
Enable Deep Packet Inspection
Why is that?
Re: ArubaOS 6.4.2.4 (Also tested on 6.4.2.3) | WIP
UCC dashboard will only show data if calls are detected. Are you trying to detect generic SIP or Lync traffic?
Tim Cappalli | Aruba Security
anything that is VOIP (SIP & LYNC)
and we cant see nothing under the UCC dashboard
You'll need to setup classify media ACLs. Have you taken a look at the Lync VRD?
OK , And ,Without the ACL (classify media) it will not work? (the ucc?) and i should build insert this ACL to the users ACL.
It may detect some traffic, but classify media ensures that an ALG gets applied and traffic is analyzed.
