ArubaOS 8.2.X.X (2 Questions) Standalone <> Standalone standby(how to share licenese? upload files?)
Hi Guys,
Good morning,
recently i deployed two 7030 controllers with ArubaOS 8.2.X.X
when starting the configuration process i encounter to issues i would like to understand and discuss with all AirHeads out here :)
1. Standalone Master <> Standalone Masterstandby (VRRP redundancy)
has been configured and working well.
BUT - how to i configure the centralized licensing from the standalone master that contain the license ? please advise ... license pool or something seems not working - getting an error that can be enabled only on MM
2.i created a customized captive portal...how to i upload the page content ? except the login html? Please advise.
Waiting to hear some advises and answers,
Have an orange mobility day to u all :)
Me
Super Contributor II
Re: ArubaOS 8.2.X.X (2 Questions) Standalone <> Standalone standby(how to share licenese? uplo
Hi!
From what I heard redundancy in 8.2 can only be achieved by using a mobility master. When configuring a physical controller as a "master" it won´t be able to terminate APs, when configuring it as "standalone" it can terminate APs but not participate in redundancy. It stands alone so to speak.
I was surpriced to hear it and would love to be wrong if anyone has something official on this.
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba Partner Ambassador
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
I think Standalone in VER 8.X = without MM ...
and why that Aruba will remove great feature.
Take a look in the following screenshot:
2018-04-16_14-56-53.pngAnd i would like to know how to configure/enable it to work.
And i had a 2nd question at my post (regarding uploading couple of files for my captive that located on the contoller - i built my own)
Thanks.
Me
This is correct
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Victor?
This is correct , What do u mean?
My bad , meaning that Chris previous statement/ post is correct
Thank you
Victor Fabian
Thanks.
so ...the screenshot i got contain bullshit info?
and what regarding my 2nd question.
me
Are you talking about the " standalone controller acting as a license
server to another standalone controller?
I personally haven't tested that setup but if it is stated in the document
I assume it is supported, but you can try testing it in a lab environment
to validate it works properly before implementing it
Thank you
Victor Fabian
When deploying a standalone / backup standalone, centralized licensing should work the exact same as it was before in 6.x. I have tested that in 8.2.1 and it should work fine. if not, please post your configs and screenshots or open a TAC case.
Hi jhoward!
Does this mean that it´s a supported setup to sell 2x controllers running 8.2.x configured as primary standalone / backup standalone for redundancy?
Cheers,
