Regular Contributor II
ArubaOS 8 Questions
Hi All,
Can someone please explain me this,
"The VMMs can be resized within VMWare (add CPU, RAM, Disk, etc) and two or more MM-VAs can be ‘stacked’ on a
VMM (ie, MM-VA-1000 plus MM-VA-500 will give you an equivalent MM-VA-1500)"
So if we need 1500 to be supported by MM do we just need to increase the CPU, memory of current MM-VA-1k and install the required license or we have to fire up a new VM and do a stacking (like we do in swtching) ?
Re: ArubaOS 8 Questions
I believe you have to stack:
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=28637
