Contributor I
Arubapedia Screen Shots not visible
I am using arubapedia for partners, https://afp.arubanetworks.com , I am not able to see screen shots in any of the documents
is it normal or anyone faced the same issue, is t here any fix for this ? it shows the below error in all the documents.
like below link :
https://afp.arubanetworks.com/afp/index.php/RAP_Provisioning_or_Reset_-_RAP-2WG_and_RAP-5WN
Error creating thumbnail: convert: WriteBlob Failed `/var/www/html/afp/images/thumb/6/61/M_RAP.PNG/740px-M_RAP.PNG'.
Ajinc
