Authentication Packet ..(Bandwidth required for Auth packet in Bridge & Tunnel mode)
I have AP 93 connected to controller 3200 in two ways .
1) some AP are connected in campus mode
2) Some Ap are connected in RAP(remote ) Mode over MPLS link
Forwarding mode = Bridge for the both cases
Question :
When i am doing authentication with controller how much is the bandwidth  consumed by  Each AP ??
Is it continious ?
Please comment .
Re: Authentication Packet ..(Bandwidth required for Auth packet in Bridge & Tunnel mode)
Answer.
Very little and it only happens when the user is authenticating.
Colin Joseph
Aruba Customer Engineering
Like cjoseph said is not much, 802.1x BW requirement is between 1-5k depending on the type of EAP method you are using.
Thank you
Victor Fabian
Lead Mobility Architect
As we discuss with our Aruba partner , told that around 100kbps per Ap is required in RAP mode...
See if this helps
Thank you
Victor Fabian
Thanks fo your page ..
I have one more dout  suppose i have 40 user are connected to AP (Access-Point).IN RAP mode
Whenever user trying to connect the SSID all authentication & 802.1x control packet goes to controller through MPLS .
Now can you provide me the bandwidth consumed by All 40 user between Access-Point & Controller .(Only Authentication & Controlling) anyway in RAP mode your normal traffic never goes to controller.
Waiting for your reply
Sambhaji
This Information is regarding The RAP mode
