Automatic provisioning of APs
Okay, here's what I'd like to do:
At any point in time, once a new AP comes up and uses option 43 to contact the controller, given the MAC address of that AP, the controller issues a bunch of commands to provision it:
config t
provision-ap
read-bootinfo wired-mac <MAC Address>
ap-group <AP Group>
ap-name <AP Name>
reprovision wired-mac <MAC Address>
exit
BUT, I want this to occur whenever the AP is actually turned up - I don't want to sit there on the line ready to push these commands.
I keep thinking a provisioning profile SHOULD be able to do this, but I can't find anything that suggests it can.
Am I really off base?  There just seems there must be a way to script this via a provisioning profile, an ap system profile or some kind of scripting....
Re: Automatic provisioning of APs
ap-regroup and ap-rename with the wired mac or the serialnumber option allow you to do this while an AP is offline.
http://community.arubanetworks.com/t5/Access-Points/Updating-configuration-of-Inactive-APs/td-p/9137
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
So, that will move an AP to a given group, that's good.   But how do you automate the assigning a name for instance?  What scripting can you use with Aruba OS?
ap-regroup will change the group
ap-rename will change the name.
Both commands can be issued before an access point comes up as long as you use the wired mac or serialnumber parameter.   they can be cut and pasted from your favorite spreadsheet program
But it didn't work......bunko was the name I used, btw......
 #ap-rename wired-mac 6c:f3:7f:c3:92:dc bunko
AP with MAC address 6c:f3:7f:c3:92:dc not found.
We are running 6.2 on an Aruba 3600 (master)....btw.....
Sorry.
The access point would need to have touched the controller once before. I apologize.....
Any way to add that MAC address into the controller somehow, so that it reads it and performs the command?
No.
The access point would have just need to have seen the controller once (standard burn-in) for it to be in the database.  You cannot add it ahead of time, unfortunately :(
So, you can't do an import whitelist?
What about the local-userdb-ap?  I can't add APs that way?
