Avaya 3641 IP-Phones and Aruba controller
We faced allot of trouble fixing the connection of avaya ip telephony with Aruba's controller, seems like there is a few thing to take in consideration before opining ticket :)
So here is the configuration made between Avaya 3641 IP-Phones and Aruba controller 3600;
From The IP-Phone side :
1-      Network Configuration à IP-Address à Static IP à
2-      Network Configuration à SSID à write the SSID assigned name on the controller(V and U look the same on the screen! Be aware.
3-      Network Configuration à WLAN settings à Custom à Security à WPA2-PSK à PassPhrase
4-      Network Configuration à WLAN settings à Custom à QoS à Wi-Fi Standard à Admission Control à Optional
5-      Network Configuration à Reg. Domain à 02 à b & b/g mixed
6-      Diagnostics à Run Site Survey ( Just to make sure AP is visible by the Phone)
From The Controller side (Eng.Ahmed Enaya Did most of the below:
1-      Updating the IOS of the controller to the latest version
2-      Making all the VLans as trusted
3-      Removing the firewall and moving the security to be from the switch side in case there is no PEFNG license.
4-      Enabling WMM (a,g Netowrks)
