Contributor I
Average Bits Per Second
Hi All,
Quick question, does anyone know why the Average Bits Per Second Out = 0bps on the overview dashboard?
This is a IAP-105 deployment with AirWave 7.5.1 demo.
Cheers
Chris
MVP
Re: Average Bits Per Second
Is this for wireless or wired interface?
Sean Rynearson
Contributor I
Wireless.... but looking at "Average usage for Wired" it is 0bps as well.
Chris
MVP
Hmm. I dunno, I will have to take a look at my server in the morning. I have always seen traffic going in and out of the wireless and wired interfaces of my aps.
Sean Rynearson
Moderator
@Chris,
I noticed that you said you're on AMP version 7.5.1, is that a typo?  Current release is 7.6.1.  Please verify by checking:
# root; svn info
# amp_version
If you're really on 7.5.1, there were several fixes that were made directly for IAP support in AMP.  In the meanwhile, I'll see if there's a lab setup that can replicate what you're seeing.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
MVP
His screenshot showes AMP 7.5.7
Sean Rynearson
Contributor I
AMP 7.5.7 sorry was a typo. I will attempt an upgrade.
Chris
