Added an example calculation here.
Original Message:
Sent: Jan 27, 2014 10:26 PM
Subject: BSSID for the SSID
Somebody provided this to me awhile ago
First Step:
The controller takes the OUI and simply uses it as the first 6 characters of the BSSID 00:0b:86:
Second Step:
This is the interesting part. The controller first takes the next character and simply removes it. 6
The next character is then taken 6
A Boolean XOR is performed using this character and the value Hex 8, creating a new character E
Third Step:
At this point the controller takes the next 3 HEX characters from the MAC address (characters 9-11) 0:da:
These 3 characters are appended to the first 7 characters, and these are the first 10 characters of the BSSID 00:0b:86:E0:da:
Fourth Step:
If the AP has 2 Ethernet ports and 2 Radios, then each Radio will be capable of a total of 16 BSSIDs
The 2.4 GHz radio will use the last HEX character of the wired Ethernet port for it's 11th character 3
The 2.4 GHz radio will begin assigning HEX values starting at 0 and incrementing to F for the 12th and final character 00:0b:86:E0:da:30 through 00:0b:86:E0:da:3F
The 5 GHz radio will increment the last HEX character of the wired Ethernet port by 1, and use it for it's 11th character 4
The 5 GHz radio will begin assigning HEX values starting at 0 and incrementing to F for the 12th and final character 00:0b:86:E0:da:40 through 00:0b:86:E0:da:4F
