Backup controller not SSID broadcast during failover
I have a MASTER/BACKUP scenario with VRRP configured. The MASTER went down and I could see all AP on the BACKUP controller, however the SSID where not broadcasted and the AP looked as they were not provvisioned (2.5 and 5 ghz leds off)
(SMPWC2) #
(SMPWC2) #show ap database
AP Database
Name    Group         AP Type  IP Address     Status  Flags  Switch IP     Standby IP
SMPAP1  Yoti_default  215      10.222.123.6   Down    2      10.222.123.2  0.0.0.0
SMPAP2  Yoti_default  103      10.222.123.14  Down    2      10.222.123.2  0.0.0.0
SMPAP3  Yoti_default  215      10.222.123.13  Down    2      10.222.123.2  0.0.0.0
SMPAP4  Yoti_default  215      10.222.123.12  Down    2      10.222.123.2  0.0.0.0
SMPAP5  Yoti_default  215      10.222.123.9   Down    2      10.222.123.2  0.0.0.0
SMPAP6  Yoti_default  215      10.222.123.11  Down    2      10.222.123.2  0.0.0.0
SMPAP8  Yoti_default  215      10.222.123.10  Down    2      10.222.123.2  0.0.0.0
Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
       I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
       X = Maintenance Mode; P = PPPoE AP; B = Built-in AP; s = LACP striping
       R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
       c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
       u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
       i = Indoor; o = Outdoor
       M = Mesh node; Y = Mesh Recovery
Re: Backup controller not SSID broadcast during failover
You need to make sure that the client VLANs on controller 1 are also configured on controller 2, otherwise the APs will not come up.  Type "show log system 50" to see what the problem could be.
The VLAN was in there. I can see the controller took the VRRP's IP but it trown a bunch of errors about config syntax (attached)
It looks like you don't have the policy enforcement license installed on that second controller:
ec 21 15:31:33 :307146:  <DBUG> |cfgm| Parsing the Configuration file to get Snapshot data
Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#312::netdestination AllPrivateAddresses
Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#317::netdestination googleDNS
Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#321::netdestination6 ipv6-reserved-range
Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#325::netdestination YotiDHCPservers
Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#329::netdestination YotiDNSservers
Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#333::netdestination Internet
Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#339::netdestination YotiNTP
Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#343::netexthdr default
Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#356::  any any any  deny
Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#359::  any any svc-svp  permit queue high
Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#360::  user host 224.0.1.116 any  permit
Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#367::  user any udp 68  deny
I would bring the first controller up and enable centralized licensing:  Configuration>Network > Controller > Centralized License Management
Ok,
I have enabled it. I'll test and I'll let you know. Thanks for your support
