Contributor II
Bandwidth restrictions on guest enforced on controller or AP?
I have a site with a main building and 3 sub buildings. These sub buildings have a leased line towards the main building and only have a limited amount of bandwidth available.
I want to enforce a bandwidth limit on the guest network, but this will only have benefit if the bandwidth limit is enforced on the AP itself. So the question is, is my bandwidth limit enforced on the AP or on the controller?
I am using a 7005 controller with AP205.
Re: Bandwidth restrictions on guest enforced on controller or AP?
It is enforced at the controller, but if traffic is enforcd at the controller, it will restrict higher bandwidth at the site, as well...
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor II
Hi Joseph,
Agreed, at the main site it will also restrict bandwidth, but that's not a problem.
Is there another way around this, using the existing equipment, to enforce a bandwidth limit on the AP?
If you would need to restrict bandwidth at a site, you should use Instant at that site, instead.  There is no way to do this with a controller-based solution.
