Occasional Contributor I
Bandwith for Guest SSID per AP
Hello all,
At this moment we have setup 2 SSID's for my company, and I would like to limit the bandwidth for the Guest SSID.
I found out that I could limit the bandwidth per ap group, but I only have 1 ap group, and since I just started to get deeper into Aruba, I could not find how to limit the bandwidth for the guest per AP. I don't want to limit it per user, but either want to limit it per office or per AP.
Can someone tell me if this is possible?
Please let me know if you require any additional info.
Thank you very much for your help in advance,
Re: Bandwith for Guest SSID per AP
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Aruba-3200-WLC-QoS-Policing/m-p/203281
Thank you
Victor Fabian
Lead Mobility Architect @WEI
