Contributor I
Basic command output question
All,
This is most probably a simple question re the output of this command:-
(LHRR1-DC-WIFI1) # show ap association client-mac 00:21:6a:53:e6:0e
Flags: W: WMM client, A: Active, K: 802.11K client, B: Band Steerable
PHY Details: HT: High throughput; 20: 20MHz; 40: 40MHz
             <n>ss: <n> spatial streams
Association Table
Name          bssid              mac                auth  assoc  aid  l-int  essid     vlan-id  tunnel-id  phy             assoc. time  num assoc  Flags
SPcomms-room  d8:c7:c8:f7:e3:59  00:21:6a:53:e6:0e  y     y      11   10     Employee  250      0x112d     a-HT-40sgi-2ss  3m:55s       1          WAB
00:21:6a:53:e6:0e-d8:c7:c8:f7:e3:59 Stats
Parameter                            Value
Channel                              36
Channel Frame Retry Rate(%)          7
Channel Frame Low Speed Rate(%)      0
Channel Frame Non Unicast Rate(%)    8
Channel Frame Fragmentation Rate(%)  58
Channel Frame Error Rate(%)          3
Channel Bandwidth Rate(kbps)         226
Channel Noise                        88
Client Frame Retry Rate(%)           0
Client Frame Low Speed Rate(%)       0
Client Frame Non Unicast Rate(%)     0
Client Frame Fragmentation Rate(%)   8
Client Frame Receive Error Rate(%)   0
Client Bandwidth Rate(kbps)          6
Client Tx Packets                    5773
Client Rx Packets                    1867
Client Tx Bytes                      609686
Client Rx Bytes                      1479824
Client SNR                           29
Where it shows channel noise 88 and SNR 29, does this equate to RSSI being 59? i.e is  'channel noise' the same as the noise floor? When I run 'inssider' the rssi from that mac to the same AP shows as 50... I am wondering is this just that inssider is unreliabe or I have misconstrued 'channel noise'?
Thanks.
Re: Basic command output question
EDIT:  I typed to quickly.
Channel Noise is the noise floor.
Contributor I
Client SNR is in RSSI? Not sure what that means, SNR is the difference between background noise and signal strength which is measure in RSSI on Inssider for example isnt it?
The measurements are take from Inssider on my laptop which shows my mac's rssi from the AP that is also shown on the command.
But is 'channel noise' as shown in the command the same as the noise floor measurement? Or am I looking at two different things?
Noise is noise floor, correct.
SNR does = power-noise floor, yes.
What version of ArubaOS is this and what access point?
Contributor I
6.1.3.5
Ap105.
