Basic difference between Instant 8.3 and Aruba Instant 6.5?
Forgive me for being a Aruba newbie- we have several Airwave managed clusters (AP315's), that are running 6.5.x firmware. I was looking to upgrade and found a version 8.3 variant of Aruba Instant. What's the difference between the two versions of Aruba Instant? Meaning is there a particular reason to run one or the other version? From what I can determine 8.3 has a longterm EOL, the 6.5 is EOL Aug 2022.
Re: Basic difference between Instant 8.3 and Aruba Instant 6.5?
Have you already read the release notes, under "What's new"?  There is too much to copy and paste here, so I will just attach them.
If you already read the release notes, do you have any questions about them?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
6.5 is current Instant software version. 8.3 has just been released weeks ago, and the 8.x versions will be where the new features will be developed. Over time, you should consider moving to 8.x.
For now, if you have a stable 6.x deployment, I would upgrade to the latest version in 6.x, unless you need features that are only in 8.3 as described in the release notes.
Thanks to all for the replies. You answered my question.
Regarding this topic,
I've got some 205 (not compatible with IAP 8.X). If I buy the new instant hardware (e.g 325), can I have these APs on the same cluster?
Thanks in advance.
Your cluster would have to run on 6.5.
