Frequent Contributor II
Beacon Frame source
Anyone know if Beacon Frames are sent per AP or per SSID? Everywhere I see the contents of the frame the SSID is mentioned as a singular term. Makes me believe that the frames are per SSID...
Re: Beacon Frame source
Beacons are per-SSID.
Tim Cappalli | Aruba Security
strictly speaking, per BSSID.
:smileyhappy:
ACCP, ACCX #817, ACMP, ACMX #294
