Beacon Rate, Basic Rate, Data Rate
This thread has been viewed 40 times
  • 1.  Beacon Rate, Basic Rate, Data Rate
    Posted Jul 05, 2017 09:04 AM
    I know there are a lot of earlier threads regarding this topic, but for me it is not clear yet.
    Especially the difference between beacon rate and basic rate is not clear.
    Can anyone help to make it clear?
  • 2.  RE: Beacon Rate, Basic Rate, Data Rate
    Posted Jul 05, 2017 09:15 AM
    Those are all general terms that are easily searchable on the internet, to be honest, and I would just be sending you a link to those.  Most admins in normal conditions do not change those parameters.
    Is there a specific situation where those parameters need to be changed that you would like to ask about?
  • 3.  RE: Beacon Rate, Basic Rate, Data Rate
    Posted Jul 06, 2017 02:17 AM
    We are in a migrate process from a different manufacturer to Aruba.
    It seems that we had some romaing issues in the past with the old system and now we want to avoid those problems with Aruba.
    Especially the Motorola MC9200 are effected.
    So, one of the first ideas was to adjust the different rate settings.
    For that we have to understand them in detail.
  • 4.  RE: Beacon Rate, Basic Rate, Data Rate
    Posted Jul 06, 2017 06:02 AM
    That is a valid reason.
    Beacon Rate = the rate at which beacons are sent.
    Basic Rate = the rate at which management frames to/from the client are sent
    Data Rate = the rate at which data to/from the client are sent.
    As a practical matter, the power of the access points has a greater impact on roaming than changing the data and basic rates.  Power affects all of the clients on the AP.  You would change the data and basic rates to influence roaming of clients only on a single SSID when you don't want to affect the roaming of clients on other SSIDs.  That would be the strategy.
    Changing from one WLAN manufacturer to the other is tricky because it is typically from older equipment that has less receive sensitivity (ability to hear clients) to better receive sensitivity.  The Aruba antenna pattern (downtilt) means that you could mount an AP with an internal antenna in the place of an external antenna.
    If this is a warehouse, please see the presentation here to start:  http://community.arubanetworks.com/t5/Airheads-Breakouts/Hostile-Environments-Wireless-LAN-Design-for-Warehouses/ta-p/247147
    If you need more help, you should hire a professional, because warehouse deployments can be tough...
