Occasional Contributor I
Best Practice for Centralized License and HA for APs ?
Hi All,
       I'm newbie for Aruba so please help me to design for H/A Environment Master/Local Centralize License Enabled , I have 300 license for AP and PEF, Should I Install All the License on the Master Controller or Half/Half with Master and Local Controller, My Aspect is I want all APs can failover to Local Controller when if the Master is Down.
So what Option i should go
1. 300 Total License install on Master Controller
2. 150 License on Master and 150 on Local
