cdj
Contributor I
Best Practice for replacing M3 w/ 7220 Controllers?
I'm currently doing lab testing on the 7220 controllers (such as centralized licensing & VRRP) but I'm going to replace our current M3 with 7220 controllers. Is there a best practice for replacing them?
I copied the production config and installed it on the respectable controllers but I'm not sure how the APs will react to a new controller even though its the same config.
Super Contributor II
Moved:
Re: Best Practice for replacing M3 w/ 7220 Controllers?
